Hello every one, i desperately need to sell because im moving.
96 Nissan Skyline R33 GTS-T series 2
First owner since import
Excellent Condition
108880kms
$14500
Manual
Perfect car for mods
Brisbane Southside
Call JD 0403718238 for any questions or inspections :(
Edited by jj383
