bah, petal has busted the climate control auto button by mashing it
its the second time we've done this to our car (first time, was teh day after we got it from street machines, so we just took it back and they fixed it)
i doubt they would do it for us nearly 4 years after we got it!@
whats the gizzo? can i just find another auto button from the wreckers and switch it myself?
or is there more to it than that?
its bugging me immensly that its not working already
i cant stand thinking about it :happy:
https://www.sau.com.au/forums/topic/141556-stupid-auto-button/
this guy is selling his whole interior at a cheap price
pretty sure this includes the climate control module.
http://cgi.ebay.com.au/Nissan-Skyline-R33-...1QQcmdZViewItem
I would buy the heater core off you if it came with :happy:
Edited by Lazy-Bastard
mmm, was hoping more just for a button purchase
jimmy out the old busted button, and whack the new one in
dunno about replacing everything
the aircon still works fine
You can try that the buttons are heaps weak they are hinged from the top with a thin piece of plastic you could probably even try to glue the hinge back together with a glue that doesnt set rock hard...I thought about it but it was easier to pay the $60 and bin the old one!
Either way I am happy to lend a hand
Oh and you dont have to replace everything it comes out as one box with a single plug on the back!
Who uses the auto button? The auto butting just equals full fan to the head... constantly... no matter how cold it is. I hate that button ;)
yeah whats with the auto button? what does it do or supposed to do other than full throttle
it works on mine, its supposed to chill things to the temp you set it at. Starts off at full, then steps down to 3/4 then half power for the fan... if your ones dont do this i'm guessing you need the temp sensor for the climate control replaced
yer, it works perfectly for me
when cabin is at temp, it just keeps it at whatever temp you have set it to
dan, write up on sau? ill have a look
edit: http://www.skylinesaustralia.com/forums/in...c=94431&hl=
doesnt sound too scary
i mite give this a burl
Edited by Spook's_Skyline
ok so instead of the aircon on all the time and making things arctic, it'll stabilise at 18 degrees?
thats actually kinda neat, mind you spring is nearly over and arctic is the only acceptable setting, but thanks =)
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
