Yep its definitely difficult to slide on especially if the attachment has a lip of any sort.
Grab a rag and smear on some rp7/wd40. Works quite well.
Just don't go overboard as wd40 i'd imagine isn't too good for the oil. :(
Connecting it to the motor is difficult and you will end up feeling like your going to break your forearm pushing it on.
Cut the oil drain off so that its straight, thats what i ended up having to do as mine too was on an angle or does it angle from the start of the attachment? :S
That bit of hose I gave you was the softest stuff I found in that size. The gear I got from pirtek was very very solid.
haha, i shouldn't have posted this in this thread, oh well!
The problem i'm having you see is that my oil drain isn't directly at the bottom of the turbo which causes more headaches with the angle that it is on, i have already chopped it shorter as i used the xr6t oil drain with a new tube welded on. Because of the angle the hose has to bend into an 's' shape which just crimps it and only the cheap shit i have seems to wanna bend without crimping!
Ahh ok so the centre cartridge wasn't unbolted and moved so that its 'square' if you like?
Have a look in the sticky there's another rubber hose bloke who deals with only hoses. Pop through there and see what he has.
I was really after just a nice rubber oil resistant hose like stock uses but Adelaide hose and belt only had the pressure stuff that tends to be a little stiff.
Speaking of which, anyone know where I can get silicone intercooler hose piping? I want 3" stuff but everyone just sells couplings that are 3" x 3". I want a longer one, about 5" long instead. Sorry for the hijack.
i thought only the 2 housings moved and not the centre bit?
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
