I have a HKS pod off my R33 which has the adapter for the standard AFM, but as far as I'm aware, i thought Z32 was a straight swap out so should be OK ??
$50 and yours....although no filter.
Anywhere between Nth syd and Gosford (or close by) is fine
(maybe you should state where you are)
:P
https://www.sau.com.au/forums/topic/141601-hks-pod/#findComment-2649859
The non GTR items and Z32 are identical, both are ~80mm and share the same filter bolt pattern. The GTR units are 65mm and consequently require a different setup.
https://www.sau.com.au/forums/topic/141601-hks-pod/#findComment-2651989
