I've decided to put my GTR up for sale as I need funds for some personal projects I am doing. This is my personal car and has been for the past 8-10 months. It was a daily driver for the first few months, however has now become a weekend car. I have had it regularly serviced, and full utmost care has been given to her.
All tests are welcome, I am confident the first to see will be very happy. It is at a very good price, considering the car was stock, all mods have been done in Australia.
Engine is very healthy, I have ran an 11.98 quarter mile pass.
Details are:
1995 Nissan Skyline GTR
Rare Black Colour
83,000 kms
Racepace Cam Gear
Apexi Power FC + Hand Controller
Rays Volks F-Zero Challenge (18x10jj)
DBA4000 Slotted Front Discs
Ferodo DS2500 Brake Pads
Extreme Extra Heavy Duty Spring Button Clutch
Whiteline Castor Adjustable Bushes
Whiteline Camber Adjustable Bushes
HKS Pod Filters
Fujitsubo Twin Pipe Cat Back Exhaust
Custom Front Lower Lip
Alpine MD/CD Player
Clear Indicators
As mentioned the car is in Immaculate Condition. Timing belt and spark plugs changed, all fluids (Engine, Gearbox, Front and Rear Diff, Brake) changed - all carried out by Racepace Motorsport. 256rwkw@14psi.
Suspension work carried out by Centreline Suspension.
More pics can be seen here: http://allblitz.com.au/cars/004_nskylinegtr95black.html
GDZ1LA plates not included.
$27,000 Rock bottom price, no offers, no swaps, no nearest offers - firm price - needs to go, thats bloody cheap !!!
Strictly no test pilots, I will take interested parties for a test drive, however a test drive can be possible after a deposit is taken.
Location - Melbourne
Car currently has R34 GTR Rims on it as seen on the white R34 on my signature. Buyer can choose to purchase with the 34GTR wheels or the Volks F-Zero Challenge's.
  • 3 weeks later...
  • 4 weeks later...
nah but im being serious ..
Dude tell me ur taking the pissss????
If u read through the thread properly it says no offers now if u had offered me 20k id give u my rims and bodykit......
Sorry allblitz for hijacking ur thread but this guy is fullllll offf it
Edited by slygtr
  • 1 month later...
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
