Just wondering what you guys think would be my best option? to import an r34 25gt myself through an importer like j spec or am i better of just buying an r34 35gt of a dealership, already complied etc, registed..
so far the bst deal if found is a 1998 r34 35gt, full nismo body kit, black, tip tronic, under 50 000ks, $19 000, with 6 months rego and 3 years warranty...
sounds like a good deal to me?, just wondering how much i would save importing it myself?? or is it just to much time and hassles?
Thanks for any help
https://www.sau.com.au/forums/topic/141674-is-it-worth-importing-an-r3425gt/
Thanks for any help
at $19,000 plus importing costs... That's a fair bit... Probably what like another.. 3 grand? or more.. Just buy local..
yeah they can be. basically whatever the dealer's profit margin is, you save. could range from $1k - 4k.
A dealer has an incentive to buy a cheap car at auction (cheap for whatever reason - damage, wear high km's etc), fix anything wrong with it, and then sell at the local market price so as to maximise their profit. Not to say all dealers are dodgy like this, but the incentive is there.
With an import broker the incentive is for them to find the best possible car for you, as they receive a fixed fee and want a good repuation so you refer your friends.
hope this helps you decide
that definitly is a significant saving of 5 k, but im scared to buy a car without seeing it? dont know if you guys feel the same.. the ks are also a lil high compared to 45 000, an the 3 years wananty isnt there, and im very impatient lol 6 weeks to long
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
