I was driving home this arvo when suddenly the hicas light came on, steering went heavy and speedo and odometer stopped working. Looking through old posts on this website on the matter it seems that the speedo cable is broken and if i replace this the speedo will work again, same with the odometer and the hicas will also be fixed. Could i just geta quick yes or no as to wether fixing the speedo cable will fix the hicas/power steering problem as well.
https://www.sau.com.au/forums/topic/141686-quick-yes-or-no-qn/
i have similar problem i have a r33 gts-t my rev meter dies and hicas light comes on at the same time and comes back on again, ive pulled my cluster out and gave it a good clean pulled all the plugs out and put them back in, the problem is still there. Theres no modification done to the hicas and i dont have any after market tachos. I think the best place to pin point the problem will be auto electrician
yes fixing the speedo will fix the sterring
hicas is proportional to the speed you are travelling, if it doesnt know how fast your going, it turns off the power steering. (or drops to minimal assist)
Thankyou muchly for that craved...very happy to hear that.
Just one more q'n, is there any chance that it is a blown fuse that has caused speedo/odometer to stop or can it only be the speedo cable?
Thanks again!
happened to me once in my r32, pulled the speedo outa box and pulled on it. the cable didnt pull through ( not broken) i then mooved onto the cluster, when i pulled that out the lil pinion for the speedo into the cluster had poped out, put it back in and bang it all worked again. havnt had any troubles since.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
