hey guys, i have a R34 GTT and im runnin 255/40/17 on the rear, they are down to legal limit of grip left..
either way, what PSI should i use to get most grip on the touge in the dry until i can replace the tyres.
its just 1 final run i need to make.
also if its damp, suggestions?
https://www.sau.com.au/forums/topic/141693-best-grip-cant-afford-new-tyresyet/
Won't matter a bugger if it's dry.Tread only reduces grip in dry weather.That's why racers run slicks at every opportunity.If it's damp you'll get tail happy.If it pisses down wait until it stops.Keep fingers crossed,take bible,watch out for black cats.
Come to think of it can't you get some secondhand ones with decent tread to tide you over? Much safer for cops and wet weather.
Edited by wun hung lo
It still does matter if the road is dry.
Yes, tread depth only matters for the rain, but when tyres are that worn, they are old and hard and ahve no traction at all.
Illusive, I wouldn't be touging anythign with shit tyres. Just drive it like a grandma until you can afford new tyres.
It doesn't matter whether you run 20 psi, 30 psi or 40 psi. they'll be shit anyways.
Lower pressures will increase your contact patch, but decrease the tyre's resistance to sidewall flex. So you're talking trade-offs.
What kind of tyres are they? If they are a sports tyre with reinforced sidewalls in the construction, you can afford to run lower pressures.
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
