Who owns the 31 with the 26 in it? Would love to know how/whats involved in getting the loom hidden out of sight. After my engine bay is resprayed, i would love to clean up the bay a little when the motor goes back in
hahahahahahahaha :(;):)
  • Replies 199
Posted Images
John... NismoR31Jet on SAU forums :(
We are doing very similar stuff to mine Troy. Its just time and rewiring some stuff. Its not major work, just time consuming
Yea....To hide the loom like that I had removed the entire dash and stripped the inner side of the firewall from all heaterboxes and all that ans ran the engine loom on the inside of the firewall then ran it through to the engine bay just under the rear edge of the inlet manifold.
Extending the AFM wiring was the hardest bit.
You went beyond what im doing though :(
I aint going to the dash lengths, just incase i need to get at it in the future.
But even then, its not really a mammoth task.
AFM wiring shouldnt have been that hard though? its only a couple of wires
A lot of my shots came out really dark, just crappy lighting or the flash wasnt doing its thing, or maybe drunk operator.
Flash is the devil. :laugh:
Turn it off, and your photos will come out a lot brighter.
(tip to remember for next year) :yes:
these photos are utter crap, but they were the only 2 pics I had which shows the clear difference between flash on and flash off.
it works opposite to how you expect it to...
flash turned on
flash turned off
I had an awsome weekend, thanks again to everyone involved!!
im seeing photo's of chicks with my car that I dont even remember....hehe. That large Macca's coke I had seemed to last all afternoon :)
believe it or not, ive only got like 20 photo's taken on my camera :), so if anyone has any of my ride, and can be bothered, i'd love to see them
[email protected]
kris has a fair bit on his vid cam, but that'll be a fair while before we go through all that an get images onto the computer.
what a weekend!, highly recomend that anyone considering to do it in the future....JUST DO IT......you wont be sorry!
Hey guys i was ment to stop buy and say hi i was just to busy over the weekend i was one of the guys in the rc stand :) with my lil 1:10th scale car haha was very very busy all weekend with answering questions about rc cars and helping out with crap was ment to come in and say hi to you guys just was way to busy but yeah you had a nice big stand i got some pics i will post up when i have some time
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
