Finally , all the parts are here and the workshop is ready !
I had a 3/4 mongrel when my Skyline went in for the works - But this is different.
Learning from the past builds, parts, bits, pieces and workshops has taught me a lot.
Can't say that I have it 100% perfect this time - but has to be better than the last try !
So now I have a 7/9 mongrel :D
I'm pretty excited -
3-4 weeks I should have it back.
Not going to speculate about peak and average power, but I am hoping for some good numbers ! And then some good times to back it up.
Geez, I havent been to WSID for ages - Can't wait for a test run !
It's going in to Race Solutions / HitMan for the works - Maroun from RS will do all the mechanical work and fabrication - and Matt will do the Haltech install and tune !
Cheers !
https://www.sau.com.au/forums/topic/141722-project-cosmo-finished-nearly/
  • Replies 147
Posted Images
ohhhhh B man I should see your car there then !!
My cars going into to be tuned by Matt next week or so :no:
My manifold just got posted today so my mechanic should have it on monday !!!!
All other parts are ready....
Maroun will take good care of your car and he is an awesome fabricater!! nice choice :D
Need help urgently .....
The 1.00 AR rear housing on the HKS T04Z is too small...
I need a 1.15 or 1.32 housing from Garrett.
If anyone wants to swap outright or I can buy outright - let me know !
Cheers,
B-Man
Nothing on the internals yet.
But when I do it won't be dramatic. SCR Seals. Maybe a mild extended port.
The motor is pretty fresh - and the 20B flows heaps enought to spin the turb. So I'll just leave it for now until - (a) something breaks and ((B) fundage is a bit better.
PS - 2Rismo ! I have been convinced to trick the auto. I'm sure you'll be happy about that. Cosmo's share gearboxes with Nissans ! ha ha - Same as a 300ZX. I'v e been put in touch with a place that can work magic on these things.
Something will break eventually with a T04 on a stocko 20B :yes:
Get some nice big porting and some tougher seals put in, and some extra dowelling and up the booooooost :(
P.S. Autos are for poofs :laugh:
Edited by d0p3y
Good man! I'm guessing BMS/Wollongong Autos or Powershift. The box should be an RE403A yeah?
Not sure on the details mate - but Maroun from Race Solutions has a mate that has done many 300ZX boxes - I think he said that they are Jatco ??? No sure but.
Apparently he can set them up for the best of both worlds - Full manualised auto with steering wheel shift buttons , fast changes - And then flick a switch and can go back to the feel of std auto.
2800 or 3000 RPM stall converter means that I will have boost straight off the line. Therefor more average power to the ground than any manual. This offsets by far any drivetrain losses of the auto.
I still don't quite understand how it all works in terms of the stally slipping etc - but I wil ldo some more research - As I don't like putting things in my car that I don't understand how they work - ha ha.
Should be a beast with the 1.32 - Now looking at 400kw at the wheels - then more if engine re done and max the boost.
fingers crossed - no b-manning !
Ye of little faith Drunkan !
300ZX Autos are RE403A's i'm pretty sure. Some interchangable parts with Skyline and WRX boxes (RE401A) but overall a bit bigger and stronger.
Nice that you can still use the steering wheel for shifts - B-Man + 400kW launch = OMG!!! :P
I can speak very highly of SCR seals too! Webby does a great job on them and I've seen them take a huge battering. Cheap too!
Jumbo - had a big think about it - and I will have the TX3 turbo project for the manual fun ! So sticking with the auto onthe Cozzy now !
Fair call.
Daaaayum babee
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
