Was up at race solutions this afternoon checked out your car very nice looks comfey inside . I thought the bubble on the back of the roof was a brake light till Matt said it was an aerial maybe I should get onea them for mine look good
Cheers Peter
  • Replies 147
Posted Images
I don't know didn't ask the question ,tried to look after you gave em a little job and said its got priorty over everything somehow I dont think he beleived me :blink:
Cheers Peter
Haltech are making a 20B loom for their E11V2 ECU - also doing some software changes to accomodate the Cosmo ignition system. Using my car to test everything..
All that should be done now - so we should be getting into the good bits soon. I haven't spoken to Matt for a few days - but I know Maroun is chanting at the bit to get started (and so am I).
More soon ......
226rwhp is the baseline.
Which is shit - OEM ECU is crap and running hell rich.
Next milestone is the new ECU with the stock setup - Hitman (matt) is uber confindent that we will get MUCH more power and economy, just with the ECU replacement.
Haltech are still working on ignition code and should be finished monday or tuesday - So that is the next dyno run.
After that - Compression check, full service and all the good bits go on.
More to come.......
More to come.......
this is before the t04 is fitted yeah?
YES mate - it's all still stock as a rock - they are getting the ECU right first - then fitting the good bits.
So the order of things goes like this:
1) Dyno run as I dropped it off to them - 226RWHP - Completed.
2) Install & tune the Haltech E11V2 ( so they can get a basemap for Haltech, so they can sell to other Cosmo owners whio just want the ECU changed) - Not completed
3) Dyno with just ECU and stock everything else. Not Completed
4) Fit the good bits (1600cc inj's, TO4Z, Fuel Pump, etc) - Not Complete
5) Tune with new bits - Not Complete
6) Dyno the final product - Not Complete.
So far we are between step 1 and 2
yay :)
i just assumed that as its been there a few weeks already they would have dyno'd it before now hence my confusion...
but coolio
cant wait for updates :)
Jimbo
Haltech have finalised the new code for ignition - a bit tricky the way it had to be done.
260 HP at the wheels with just the Haltech - standard boost 11.5:1 accross the board.
Engine is a little bit low on compression - but nothing to stop the next stage.
Stay tuned.
  • 1 month later...
Since engine was low on compression and I didn't want to risk anything - Have decided to go with a full race prep engine rebuild - which is why this is taking so long.
Fully Dowled block
Mild Ext. Port
Race seals and spring
The whole shebang
then all the good stuff goes on
Should be ready end of Jan.
Yeah Pete,
They were gone a long time ago - all three std cats have been given the boot. Actually the whole std exhaust has gooooone - Have a nice brand new shiny 3" -> 2 x 2.5" system with one big i flow cat. no resonator and two cannons at the rear - Zorst is FREE FLOW man
Fully Dowled block
Mild Ext. Port
The whole shebang
Good.. told you not to bother with an unopened motor :)
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
