  • Replies 147
Posted Images
B-Man gives no fark for manual tranny. B-Man leaves all the trannies to Beer Baron :)
well as you know if it wasn't for my fascination with trannies we never would have met 2rismo.. or should I say delila? :):)
Ordinarily I'd say Steve Butchard from BMS as he makes fully manualised, normal (forward) pattern, NO ELECTRONICS modifications to JATCO's. He makes a transbraked valvebody for them that is the shiznit.
I don't know how seriously you're going to want to drag race the car so unless you plan on putting slicks on it and turning into a rotary drag nut, I wouldn't bother with the transbrake.
You should make a call to MV Automatics in S.A. and speak to him about the manual valvebody he does for the JATCO's. If it's the 300ZX box, it's an RE403A. Exactly the same valvebody as a Skyline RE401A and in fact, most of the parts are interchangeable. (403 will handle more torque than a Skyline/WRX 401A but the larger components absorb more power. A reasonable trade-off in the circumstances.)
If Mike at MV can build you a box that is:
A/ Completely manualised
B/ Fitted out with tough steels, bands, clutches, etc
C/ Refurbished and re-bearinged (is that even a word?)
D/ Equipped with a converter of his manufacture
...then I'd say go with him for the box. He certainly knows his shit when it comes to JATCO's and although there isn't a transbrake option with his modified valvebody (i don't believe anyway) and the over drive (4th) gear will be a function of an electronic switch (possibly like it is now) it is almost certainly the best way to go about strengthening your box to handle what you're about to feed it.
Cheers,
Adrian
And there is a good chance you can get this to your door for under $3500.
What will be your redline bman? (Thinking about convertors)
Around the 9,000-10,000 RPM mark :)
Found a bloke on AusRotary with a mad 20B Cosmo - he's ripping his engine out and putting it in a tube drag car - his tranny is for sale - it's an MV modded one with a 4200 RPM stally (maybe a bit to high for me as my boost will be on by 3000 RPM easy )
what exactly does the numbers stand for?
13b and 20b
i know one has two rotors and one has 3 rotors?? are they the displacement of the rotors?
the engine displacement...
13 = 1.3L
20 = 2.0L
i could be talking out my arse tho
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
