As the title states I am looking to sell my turbo gear as unfortunately :yucky::sick: the set up won't work with an RB30 bottom end as the turbo sits to high.
The manifold has the larger runners compared to any of the other cheap manifolds - it also lines up perfectly with all the head ports. As the photo's show the manifold is very well built!!
The turbo has a 0.82 rear, has done in between 5 - 10,000kms and still seems fine, compressor cover is polished
The wastegate is a tial 48mm US made wastegate of very high quality - would consider selling setup w/out wastegate if anyone is interested.
Also comes with water and oil lines off my RB25DET - done about 5000kms,
Looking for $2600 for a proven setup
PM or call me on 0417 438841
Edited by turbo87
hits full boost around the 4000rpm mark- this will depend on alot of things tho as my motor was only running approx 8.5:1 comp, a standard motor should hit boost earlier,
Yes may sell turbo seperately so make an offer.
Cheers,
Paul
Bump
Will accept $2600 for the lot
May consider selling the dump pipe with it - pickup only
Edited by turbo87
    • Sell it and buy something newer? 😛
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
