  • Replies 92
Ok guys, the map is done.
Route basically involveds a cruise from Mulgrave to Emerald to Montrose
to Mulgrave to City to Show 'n Shine.
Not sure on KM's that its not more than a full tank.
I suggest that we meet at the first meet point at 10am (sorry so early Luke) but the SAU SnS starts at 10, so the cruise i've planned out will take about 3h with breaks before we get to the SnS.
I will bring maps with me on the day, so no need to print them out, BUT, the meet point is Mulgrave McDonalds at reference 71 B12. 10AM meet. PLEASE be on time, will want to leave McDonalds at around 10:30AM
My mobile number is 0439 909 610 if anyone needs to contact me as they are running late etc.
See you there!
PS. I say this cruise is open to NON-Stageas BUT only if they are friends of ours. AKA, no random VL turbo driving bogans.
Important Please Note:
Neither SAU nor it organisers are responsible for any damage to or loss of participant property or vehicles.
Neither SAU nor organisers will be held responsible any unsafe driving.
This is a friendly meet/cruise which is meant to be fun and relaxed. If you plan to drift the mountain or be a hero then take it to the track.
You attend this cruise at your own risk.
Thanks Alex for the map.
Please also note that Alex has noted Sky high as a stop off. The entry to this carpark is a hefty $3.
If you require a loan the interest rate is currently 25.34% p/minute :blink::wave:;)
Edited by humble
10 ... hmmm ... l'll meet u guys at the SAU SnS.
No chance l'll be up at 10am ... 1pm l can do after a night out!!! :( :(
I'll call u alex or Ian to find out what the go is, and where u guys are when i'm half sober enough to drive.
OK people
Now that the cruise is this weekend it would be good to get a final hands up on who’s coming so we know how many maps are needed.
MEMBER INTERESTed:
1. AlexCim
2. Munchdesign
3. Flysly
4. wagon
5. MRNISN
6. Tracey (non member)
7. MattD
8. FUZZY
9. Me
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
