Last Friday night, cruising at about 100Km, pretty neutral boost (approx 2000rpm in 5th) and died in the arse. Motor still starts with a lot of difficult on cold starts, runs rough and idle hunts, no excessive smoke/backfiring. When it went it felt just like it would when an intercooler hose pops off. But they are all fine. :yucky:
Best way to describe it is like a giant torque hole before about 4000rpm, you can put your foot flat & drive through it, then makes power from 4000rpm onwards. About 20mins before it happened it felt like it was missing a bit around 4000rpm when under a slight load.
Diagnostic steps taken thus far on the RB26:
All hoses were fine – 1 very small vacuum hose was off at the rear of the motor
Replaced AFM’s – no probs
Replaced CAS (with 3 different ones) – no prob
Plugs – fine
Compression – fine
TPS - fine
FC – input sensor volts fine. But timing was out between what the FC thought it was reading/sending & what the timing was actually at the engine. Was more retarded then what the FC thought, FC couldn’t advance the timing.
Thought it was the FC, swapped FC with Wolf 3D, seemed to work a little better, but still couldn’t get a satisfactory tune in the Wolf for down low.
Reset FC to base tune, after trying to dial in a conservative safe tune it seems to go into ‘limp home mode’ ditching the parameters & puts the engine light on.
The AWD light is now coming on too, usually this indicates that the ATTESA has shut down the AWD.
Next thing to check maybe inlet manifold gasket.(?)
Any ideas? :sick:
dude it can be a range of problems, id be cheking the trubs, maybe one let go, or it could be your coils, your plugs, as i said a range of problems. have it diagnosed at a professional workshop.
What does the ECU error code functions say?
I am having probs not quite the same though and get error 34 - knock sensors (Just replaced!)
As Matt said it’s at a professional workshop.
:) Don’t think it would be a turbo, no pop/bang when it went, it was also on fairly neutral boost, & it still makes heaps of power above 4000rpm.
No diagnostic error’s on the FC, but it wasn’t setting the correct timing…
Now engine warning light comes on since resetting the FC.
Any other ideas?
Got the wolf 3D to work, no stock ECU anymore, just swapped the stock ECU for an oil cooler... :)
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
