Last Friday night, cruising at about 100Km, pretty neutral boost (approx 2000rpm in 5th) and died in the arse. Motor still starts with a lot of difficult on cold starts, runs rough and idle hunts, no excessive smoke/backfiring. When it went it felt just like it would when an intercooler hose pops off. But they are all fine. :yucky:
Best way to describe it is like a giant torque hole before about 4000rpm, you can put your foot flat & drive through it, then makes power from 4000rpm onwards. About 20mins before it happened it felt like it was missing a bit around 4000rpm when under a slight load.
Diagnostic steps taken thus far on the RB26:
All hoses were fine – 1 very small vacuum hose was off at the rear of the motor
Replaced AFM’s – no probs
Replaced CAS (with 3 different ones) – no prob
Plugs – fine
Compression – fine
TPS - fine
FC – input sensor volts fine. But timing was out between what the FC thought it was reading/sending & what the timing was actually at the engine. Was more retarded then what the FC thought, FC couldn’t advance the timing.
Thought it was the FC, swapped FC with Wolf 3D, seemed to work a little better, but still couldn’t get a satisfactory tune in the Wolf for down low.
Reset FC to base tune, after trying to dial in a conservative safe tune it seems to go into ‘limp home mode’ ditching the parameters & puts the engine light on.
The AWD light is now coming on too, usually this indicates that the ATTESA has shut down the AWD.
Next thing to check maybe inlet manifold gasket.(?)
Any ideas? :sick:
dude it can be a range of problems, id be cheking the trubs, maybe one let go, or it could be your coils, your plugs, as i said a range of problems. have it diagnosed at a professional workshop.
What does the ECU error code functions say?
I am having probs not quite the same though and get error 34 - knock sensors (Just replaced!)
As Matt said it’s at a professional workshop.
:) Don’t think it would be a turbo, no pop/bang when it went, it was also on fairly neutral boost, & it still makes heaps of power above 4000rpm.
No diagnostic error’s on the FC, but it wasn’t setting the correct timing…
Now engine warning light comes on since resetting the FC.
Any other ideas?
Got the wolf 3D to work, no stock ECU anymore, just swapped the stock ECU for an oil cooler... :)
    • Time to pray to the oil pressure jesus
    • Nope, still smaller rear, put on the 4inch exhaust and picked up power everywhere, ended up just shy of 800rwhp.   Didn't seem to be hitting any walls either, so perhaps could have pushed for more but all maybes and the fish that got away etc etc.
    • Races cars don't care for VIN either...
    • This could be sold and shipped to the US for many gold pieces. RMS has no say in that. Ask various Western Sydney inhabitants how it works.
    • Ha ha ha, mine loves to spend, all on the dogs (they're our kids, and her spending would likely rival that of some people raising children!) the only benefit is, her spending is tax deductible as she runs a business in the dog industry 😛 The above all means she can spend race car budget quicker than I can. 😛 That and a lot of the things I want are very expensive, and I can be a bit "you want how much for that?!" And at other times overly impulsive. Or I start the w days of research, get to day 1.5 and get really annoyed that no one will advertise actual specifics and it's just marketting BS and I go "well, now I don't want anything to do with that now!" Also I hate paying lots of money for something I can make from $50 in materials. Then I get the shits halfway through making things and wonder why others who just buy parts have more fun... 😛
