I've read a few discussions in the forums on how long people idle their car for (if any) before they drive off, but there's no discussion on WHY it's better to idle for a few minutes or just drive straight off...
Now for the question : I was talking to a thermodynamics professor a while ago and he mentioned that while it is true that oil doesn't fully protect your engine until it is at operating temp, your car is better protected if you drive off straight away and get it up to temp as quick as possible (as long as you don't rev the engine too much); instead of idling for a few minutes to warm it up at the first start in the morning.
Whether you have a turbo or not is irrelevant for this question.
Comments?
https://www.sau.com.au/forums/topic/14177-cold-start-damage-why/
I cant give you the technical reasons, but I have been told during discussions with a engine builder that once the engine has full oil pressure you should start driving it. Gently of course (off boost).
I would guess this allows for the oil to start flowing properly, heat up more evenly etc.
Basically, before you first start your car from cold (say in the morning) all the oil has drained down into the sump. It's at ambient air temperature, so it's going to be pretty viscous and not likely to flow freely...
You turn the key and start the engine. Since the oil pump only works when the engine is running, and it takes time for the pump to pump cold oil from the sump up into the valve/cam area (and throughout the engine block)
So, you can see that for a certain amount of time the engine is running without any oil!
The exact time it takes for the oil to start flowing freely through the engine depends on many factors - pump efficiency, oil grade, oil temp, climate and the size of the engine. I remember reading that on some older american muslce cars it could take around 2 minutes for the oil to start circulating around the block!!
Since an engine running without oil is BAD, the best thing to do is minimize the wear by not driving off imediately after you've started the engine...Basically you're giving the engine time to become fully lubricated before you put any pressure on it.
Ohh, and turbo motors are even more susceptible to this since the turbo is sitting right on top of the engine - far from the oil pump...
That's how I understand it anyways...:D
After about 15 mins of driving, my oil preasure drops to about 2 Bar, sometimes a little less (on idle that is), while driving it is typically around 4 Bar. I assume this type of behaviour is correct?
I always let mine warm up at least 1 minute, revving it a little (2000rpm - and not continously), so oil can circulate.
yeah i notice that within 10 seconds of turning the key and starting the engine my oil pressure reaches about 4-6bar (depending on how cold it is). After those 10 seconds I'm happy to drive off and after a couple of minutes driving the pressure drops to about 2 bar as the oil heats up. I think most of the damage is done in the first few seconds after startup. Once oil pressure is up then the engine is fully protected.
I let my car idle for whatever time it takes to start it up, reverse out of the garage, shut the side garage door, get a popper out of the fridge in the garage, put the roller door down, get in, put my CD Face in, window down, seatbelt on and get comfortable......
about 2 mins :D
There are many schools of thought on the warm up issue. Some people like to warm their engine up till the temp gauge rises, and then drive off, ensuing their engine is protected.
HOWEVER, you also must remember that the diff and gearbox oil are NOT at optimum operating temp from cold, and even though your engine is warm, doing burnouts etc with cold gearbox / diff is a recipe for a large bang - trust me, i've blown up a number of diffs in my time, a couple backing out and squirting it too hard (not a skyline though).
So, while i think it is important to warm up a bit before driving off (say 2 mins), you should really take it easy for the first 5-10 mins of driving time (under 3000rpm) to make sure diff and gearbox are happy too.
my 2c
Agree with you on that.
In the past I thought I had a problem with my gearbox - difficulty engaging second gear. Turned out that I just wasn't given the gearbox oil enough time to warm up (especially in winter). Not moving, or moving a slow speeds isn't going to warm up the other oils in the car....
okay well from my experience with my old torana race car.... i was young and silly and i had a mate i had to impress so i started it and revved it pretty hard after a little while of idling... about 8k.... went for a spin and wemt to like 8.5k several times and when i put it back in the shed it was fine ... when we went to take it to the drags the next wekend it developed a very bad miss...we changed coild ,plugs,leads,everything......ended up been a broken valve spring......all brand new done like 5 hours on the dyno......was broken from it not been warm enough and the wire in the spring not been ductile(flexible) enough which cause it to break...personally i would rather letting it get to operating temp before driving....reason been that the oil may not be at full protection till operating temp but it has no load on it unlike driving the car......hence idling it will not stress anything till it warms up and you take off..... i alwats warm mine fully before driving.......
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
