DREMEN: you wont need to worry about injectors and fuel system until you start running bigger turbos etc.
If you havent already done the front section of your exhaust ie the dump pipe, front pipe and cat then do that first.
Following that a Power FC will give you a substancial increase.
After that you start looking at rebuilding/replacing your turbo, which will then present the need for bigger injectors etc in your quest for more horsepower.
* Full exhaust (if it isn't already), this'll give you better midrange response and an increase of around 7-10rwkw
* Exhaust side Cam Gear
* Good Tyres (no point having heaps of power if you can't put it to the ground)
* How many km's has it done? If its more than 70,000 throw a new clutch in it, you'll be suprised at the difference
Forget about a bigger turbo and aftermarket ecu for now, theirs still more to beat out of your standish setup before you look for the easy way out. Besides once you start throwing on a bigger turbo you often forget about the tiny little things that can make a difference.
OK its done over 70, 000km's so I would be looking at new clutch
I will run 12 psi through it (We will increase it on the dyno to check for detonation)
High flow cat - I don't want to remove the standard because I just got ripped hard by the EPA 2 weeks ago :D
Dump pipe...
Cobra exhuast do a high flow cat & dump pipe for $700ish
What about an apexi AVCR?
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
    • Got my 34 gtt tuned last week. Car made 362 wheel horsepower at 19 psi. Turbo was the ATR43SS. Only other upgrades were haltech 2000 series. 650cc injectors, walbro 250, fmic. Pro hub dyno reads 6% lower than actual figure according to my tuner. Car is a real ripper now.  IMG_7261.mov
    • Hi everyone, I'm wondering if anyone in Melbourne (preferably West) has a non-S2 R34 front bar. If it's already off the car, even better!  Nothing too weird, I just need to get a cut-out of the hole that the front indicators clip into 🤣 (image attached for reference)   I've got a front bar from JSAI Aero, but those holes need to be cut myself, and I want to get it right so the indicators will clip securely. And my OEM bumper is a S2, so I have no reference. So looking for a member who might be able to spare me a few minutes to make a cardboard cut-out using your front bar.
