Hey there,
hoping somebody can help me with my prediciment.. i have a dominator car alarm i bought to replace my dodgy old VDO one which crapped itself and after seeing the absolute dodgy job which had been done when i chose to have it 'profesionally' installed last time i decided to install it myself.
everything on the ignition side of things was connected as per the wiring diagram and then checked at the plug that connects into the alarm unit itself with a multimeter for correct voltages at all stages of the key turn (off, acc, on and start as well as the +12v and the chassis earth connection). the relay was also installed as per the wiring diagram
at this stage i decided to attempt to start the car and found the car would turn over just fine, which of course it shouldn't have with the unit it place.. at first i thought i must've made an error in wiring in the relay, but i went over it and found that it was all good and as per the install diagram. the harness the relay plugs into is all colour coded which makes me believe the manual is wrong.. the alarm actually features a remote start button so i think this may have something to do with it, but really unsure.
i then tried to use the remote, but the only signs that the alarm was even alive were a few faint relay clicking sounds coming from inside the unit when i turned the ignition through it's variouse stages.
i then wired in the siren, thinking that perhaps as this was listed as the backup battery it was required to make the alarm function.. there was no clear diagram on how to wire this in, only a trigger wire was specified on the main harness, however there was a pinout on the back of the siren itself so i improvised and ran the +12 and -ve earth connections (multi meter tested) and ran the -ve trigger to earth and ran the positive trigger wire (as specified on the back of the siren) to the alarm wiring harness.. and still no change
at this stage i read a sketchy bit on how to program in the remotes in the install guide, and followed it as best i could (ignition on and off 4 times, then press all 4 buttons on each remote you want programmed in.. from memory), and still nothing..
i also connected the variouse shock sensors etc up to see if that would make a difference and none of the lights on the sensor units would come when i shook them.. the status light also had the wrong connector on it and would not plug into the main unit, so i improvised and found a connector to suit and wired that in and found that the status light wasn't coming on either..
i'm starting to believe that i have a dodgy alarm unit but perhaps i've screwed it myself doing the install.. but if anybody else has any idea's or has had simerlar experiences with the alarm in question then please help me out :pirate:
thanks in advance guys,
mark.
https://www.sau.com.au/forums/topic/141799-dominator-car-alarm-troubles/
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
