Hey guys im new to this forum, new owner to a r32 gtst love it, though i am getting a few problems with the engine cutting out under load. my mechanic suspects it the air flow sensor.
which come to my next question does anyone know any wreckers in sydney around the liverpool/fairfield area that would stock r32 spares.
not really keen on buying a brand new one and it doesnt fix the problem
cheers
dave
https://www.sau.com.au/forums/topic/141817-jap-wreckers-in-sydney/
SSS Automotive have got me out of trouble many times:
Their located in Girraween
PH : 98966111
Unit 6, 120 Gilba Road, Girraween. NSW. 2145.
http://www.sssautomotive.com.au/
I picked up a second hand air flow meter for my R32 GTST from their for $50 :pirate:
Edited by Dave69001
Hi Dave, welcome to SAU.
The first place I'd try is the SAU for sale section. Prices are generally much better than a wrecker. Just keep an eye out. You could even post in the Wanted To Buy forum - guys may even come to you to offload their spares. :pirate:
After that, SSS as Dave mentioned above, or JustJap on Bath Rd at Kirrawee.
Mark
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
