I just got a pair of HKS GT2530's rebuilt with Garrett parts. I know that HKS put the oil restrictors in from the factory, but i've read that Garrett don't.
I ordered a HKS GTRS gasket kit from nengun, and that came with a oil restrictor. Sould I use it?
Thanks
https://www.sau.com.au/forums/topic/141833-turbo-oil-restrictor/
Garrett do, any Ball Bearing turbo correctly built/assembled will have an internal restrictor on the cartridge itself.
You cant see that till you pull it apart though. The pics you have an external ones.
I know the Garrett GT30XX series was a .8mm (if memory serves me correct) :(
And that was 2 years ago when i had it, so Garrett were doing it back then for sure.
Being Garrett make the HKS turbos aswell, i dont believe you have an issue.
They dont actually "put" them in.
If you saw the inside of the cartridge you would know what i mean, its on the actual bearing housing itself... so its like that from the production line.
Im sure MTQ will be able to explain in better english :(
I have heard with GT3540's some people have been having trouble with leaking turbo seals due to the high oil pressure run by some high performance engines, Garrett supply another oil restrictor smaller than the inbuilt one if people have trouble, not sure if you would need one or where to find them
No, as i said... There is a restrictor on the cartidge.
There is only going to be "X" amount going in there whether you run 50 restrictors or one before you get to the cart itself.
If you fit a larger restrictor before the restrictor on the cartridge, then obviously it will slow the oil/volume down to the core, but once it reaches the core its only going to let in what the internal one dictates anyhow so to my limited understanding of fluid dynamics, it makes no difference.
Contact MTQ and see what they say, but i never ran anything more than the internal restrictor for my GT30 and i had an N1 pump etc.
I could name a dozen others who have done the same with thier setups, not one has blown a seal or had adverse effects.
If the twin setup is different, i would like to know why :)
If you look at your second picture you can see the restrictor in the oil inlet hole . Its the hollow mushroom shaped gadget that needs an inverted flare fitting . All these GT25 BB centre sections have them , actually its the stem of the restrictor that does fore and aft location of the bearing pack itself . If its not there the turbine and compressor try to shunt backwards and forwards depending on which side has the greatest thrust load at the time driving its opposite wheel into its housing - not good .
I guess two restrictors can't hurt but I'd rather have the one only in the turbo because it has unrestricted flow to within a couple of cm of the bearings .
Cheers A .
well up here in qld there have been a few people blowing seals out at the track...gt30s and 35s alike. Alot of people are now starting to run an inline restrictor that sits right before the cartridge one. I think its about 40psi of oil pressure is the max required for the turbo. Does that sound right disco?
Edited by r33_racer
I still havn't got round to contacting MTQ. been to busy doing other stuff on the car to worry about putting the turbo's on yet. I'll post MTQ's responce when I get round to ringing them.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
