Hi, everyone
I'v had a 95 r33 gtst for 8 months now and like most people that buy a skyline, mine hasnt skipped a beat since first driving it many months ago.
As with everything though the power bug has bitten, and rims a catback exhaust, air pod and medium size hks fmic just doesnt do it for me know. So..... with close consideration of power and street, track use, this is what my list looks like at the moment
Hybrid fmic
KKR 480 turbo (internal gate)
high mount man
bigger injectors
walbro fuel pump
greddy plenum
tein super st coilovers
apexi power fc djetro
AVC-r
twin plate clutch
and other little things, guages etc
In another month or so, new 18 inch rims, bodykit (not over the top) 2 way lsd, hopefully that will keep me sustained for a bit. Living so close to the motorplex should make it down for few runs on the drag strip.
Once i get dyno readout's il post them up, wish me luck :(
https://www.sau.com.au/forums/topic/141837-my-r33/
Apexi dosn't do djetro for rb25s, the last i checked.
KKR turbos are cheap but have seen some issues, i'd reccomend you to go with bigger brands hks, garrett,etc.
Fix your final hp, and work from there, a too big fmic will cause some drop in performance and some lag. So check that u're not gettin too big a fmic for your power figures, big is not alway better.
My .5 cents worth
Good luck on your ride!!
Show us the stuffies when u're done!
P/s: If you're gonna be pushing some serious power, you might need an engine rebuild with forgies, sooner or later. Save some $$ for that. And you definitely need a new fuel pressure regulator... of course if u do it with a performance shop, they'd tell u that for sure.
https://www.sau.com.au/forums/topic/141837-my-r33/#findComment-2642172
Rev the car may have already had them on when he bought it...
Good mods, once upon a time I thought a list like that would be as far as it was for me, but a ecu & turbo upgrade, then an engine build later I'm starting to wonder if I've changed my mind.
I object to your cosmetic mods when they are just for show, but it seems that's just me :( Good luck!
https://www.sau.com.au/forums/topic/141837-my-r33/#findComment-2642359
Cheers, guys, and gal for the replies,
thanks for giving me advice and letting me know what you think, it really helps when your moding your car. Without alot of first hand knowledge myself (and none of my friends with an import turbo car). The only problem with that, is that everyone has there own opinions. Whether is through friends, family or first hand accounts each person puts good cases forward, in the end it is the owner of the car that has the ultimate decision. I'm not diving into modding my car with the perception that nothing will go wrong, because being on here and reading some tradgedy stories of engines blowing up and turbo's failing it comes to a point where you do realise that the world is not a perfect place.
Now i have some thinking and number crunching to do,
Early next year when work clears up, im sure to join skyline WA and hope to enjoy everything that this culture has to offer.
https://www.sau.com.au/forums/topic/141837-my-r33/#findComment-2643385
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
