Be sure u do that mate....i cant stand those *#$*.....Couple years ago i had a ET turbo pulsar which was pinched from my backyard.........can u beleive that?
When i found it, it had nuthin but the shell......so next time u see any ass near your car lookin sus........kick thier ASS!!!
well at the moment i have full dodge setup probably cause i drive a laser..... i am buying a 32 in 2 months...
i have a oldschool alpine cassette head unit so i have hooked my mp3 player into it....
i have a set of sony 3 way 4 inch speaker
i have taken my home stereo speakers to put in the back and i have 2 alpine type R 10's running off a crossfire amp
  • 2 months later...
Atm...
Aiwa MP3/WMA headunit
Nakamichi 12" sub rated at 456 RMS
Rockford Fosgate amp dedicated to sub rated at 429 RMS
Alpine 120RMS 6.5" Splits and JVC 6.5" coax's
Alpine amp under seat for front splits and rear fill JVC's.
Also have waiting to go in...
custom made dash based on an R32 GTSt dash (bit of fibreglass work and stuff)
14" Benq screen, 10 degree viewing angle, 4 sources including DVi.
Xbox, modded with 120gb HDD
Polk Audio Dolby/DTS 5.1 decoder for car audio
HKS Camp ECU Visualisation
Hopefully once the car's mechanicals are finished setting up then I can go about setting up the in car surround sound system for use with the Xbox.
Hey all,
At the moment my specs are these:
Headunit - Panasonic double din with moving facia - cd md and casette
Front speakers - Pioneer 6.5 inch splits
Rear spreakers - Pioneer 6 inch 3 way speakers
Subs - 2 x 10 inch lanzars powered by 2 x 1000 watt Saint USA amplifiers.
DVD - Panasonic single DVD player with dash mounted screen.
Previously
Head Unit: Pioneer DEH-P6050
Front: Alpine 6.5" splits, passive crossovers
Rear: Factory upgrade carbon fibre-look Bose dual cones
Sub: Fusion fpw-1500 DVC 15" sub, custom 85L box, twin 4"x23" ports
Amps: US Audio 4x50W running front splits, Rockford Fosgate 250m² running sub
Power: US Audio amp ran 8 guage wire for both earth and power, and a 40 amp fuse. Going to the Rockford I had 4 guage wire to a 1 farad capacitor, then to a distribution block, which split into 2x 8 guage power wires (dual monoblock amp=two power sources). 2x 8 guage earth wires to the cap, then 4 guage to a rather large earthed bolt. NFI how the stock alternator survived.
Was pretty loud, farkin bassy, and sounded pretty good for a system that cost me under $2k all up, but it wasn't doing clips/screws/interior trim much good, and I had no usable boot space - large power wires and an amp that ran very hot meant that I didn't like piling stuff up on either side of the box. It ended up stretching the shit out of my boot lock so I pulled the sub and Rockford amp out.
Now
Head unit: Pioneer DEH-P6050. Volume buttons worn through
Front: Alpine 6.5" splits. Both have blown voice coils
Rear: Bose rear fill. Fine!
Amp: US Audio 4x50W, still running the fronts
Sub: None, but I have my boot back!
the word that best describes my system is "secondhand" - all of my parts have been bought secondhand. Not quite complete as I'm yet to purchase an amp (Audison SRx3). But so far it consists of:
Source: Sony CDX-M630 (meh)
Splits: Focal Utopia 165W2
Sub: JL Audio 10W3D2
The stuff that's currently installed is Alpine DDDrive 2-ways front and rear, old Alpine tape unit with AInet 6 CD stacker.
  • 3 weeks later...
What kind of audio systems are you guys driving around with?
STANDARD!! :)
if anyone here wants to unload their old 'double din head unit, ie...single slot cd/radio /tape deck' ........(if it looks nice and works), please pm 'SUPERSPIT'
I will pay a reasonable price!!
Ta, Mark. :)
Last week I installed:
Panasonic CQ-C9800U CD player with 4 x 60w digital amp
Focal 136v polyglass splits (135mm)
Decware DBII 'Deathbox' bandpass woofer box
Sony 10" dual vc ex-plod woofer (used, sounds fine for $100)
The Panny uses Tripath digital chips, and puts out a real 60w rms / channel. The sub box is about 450 x 325 x 325 so it's not small for a single 10, but it does sound good. The box is adjustable (to suit different woofers & cars) so maybe I can build a smaller one that goes in the battery compartment. This system isn't loud; I'm used to 2 x 12's in a 120 l sealed box & 3 big amps. That stuff added a LOT of weight to the ol' VL... I'm not doing that again.
Z
Alpine 7878
JL Audio 500
JL Audio 300/2
JL Audio 300/2
JL Audio 300/2
Nakamichi 300 watt amp
2 12" Boston Acoustics Comp
2 sets 6 1/2" Boston Acoustic Pro Series Components
1 set 6 1/2" Oz Audio Components
1 set 4 1/2" Boston Acoustic Pro Series Components
It sounds pretty good.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
