My rego runs out next saturday so I needed to fix all the cars problems which were:
1. Replace cracked rear rotor.
2. Fix exhaust leak - diagnosed as turbo to manifold gasket cos I could actually see the missing part.
3. Clean up after my dodgy catch can.
4. Also borrowed a GTR bov to test fit to see if my stocker is leaking and causing my gradual boost drop. I know not for rego but still needs to be done.
1. was pretty easy once I took the handbrake off. Doh!
3. Easy.
2. Was very proud of myself because I was able to replace the gasket without removing the turbo or exhaust, just undid the exhaust mount nearest the front.
4. Decided to go temporarily atmo because the GTR bov has a larger diameter outlet than the stocker. Confused myself when I installed it and realised I had an open pipe where the plumb back used to go but I used 4 thicknesses of heavyish plastic held on with a hose clamp to fix that.
Started her up and the bloody exhaust leak was still there!! WTF!! And, the car wouldn't idle properly.
I put my hand over the bov outlet and that cures the idling problem. What's going on there? Is it leaking? Is it supposed to?
I went for a drive and the exhaust leak seems to be less but it's confusing and annoying. I noticed that the face of the turbo where it mounts on to the manifold doesn't seem to be perfectly flat. Does this happen often? Can I get it machined flat?
So either the warping is too bad to fix with a new gasket, there was always another leak, or I just didn't tighten it up enough (which I don't think cos I did it pretty tight).
Arrgh!
https://www.sau.com.au/forums/topic/141940-frustrating-day/
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
