Hey Guys,
I'm excited to report that Buffy is almost back to normal. (yes my cars name is Buffy the V8 slayer, I've watched early 1990's Bathurst reruns one too many times lol).
Anyway, I have had all four mag wheels rolled and repaired to get them round again. The process damaged the outside lip of the wheels so I painted them black. Not too sure if I like it or not at this stage and I am contemplating painting the rims just black. Any comments ?
The guard has also been fixed and looks great. Just need to give her a full polish now.
Yesterday I was at Mick's from Signature Performance and we changed every fluid in the car. The front and rear diff oil was a bit burned along with the gearbox oil, the engine oil was bad and the 4WD oil was yuk. We did the proper bleed using the wire under the kicker panel to run the 4WD pump. The flow was sad for the first few runs of the pump but as the new oil came through the flow also improved. I'm hoping to notice a better response from the 4WD system next time I hit the track.
So next is a catch can and a tuning session on the dyno. Then I should be right for track day.
On the handling front, I have front camber adjusters coming and should be ready. I'll probably run the street tyres at the track to get a baseline of where I'm at.
Many of you know this has been a long process getting her back running. I can't wait to get into some cruises etc once she is all sorted.
https://www.sau.com.au/forums/topic/141942-buffy-is-almost-back/
The rim repair guy is down the gold coast, his name is Noel 55376380. Price was really good. I just gave him all four wheels. Nice to not have that vibration anymore. I think they got damaged from age, potholes and ripplestrips.
She has been off the road for a while, the car was perfect until I started some mods that didn't go so well. But all of that has been sorted now and I have a two stage plan with Mick to get her where I want. Can't wait. I have missed so many cool events.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
