Hey Guys,
I'm excited to report that Buffy is almost back to normal. (yes my cars name is Buffy the V8 slayer, I've watched early 1990's Bathurst reruns one too many times lol).
Anyway, I have had all four mag wheels rolled and repaired to get them round again. The process damaged the outside lip of the wheels so I painted them black. Not too sure if I like it or not at this stage and I am contemplating painting the rims just black. Any comments ?
The guard has also been fixed and looks great. Just need to give her a full polish now.
Yesterday I was at Mick's from Signature Performance and we changed every fluid in the car. The front and rear diff oil was a bit burned along with the gearbox oil, the engine oil was bad and the 4WD oil was yuk. We did the proper bleed using the wire under the kicker panel to run the 4WD pump. The flow was sad for the first few runs of the pump but as the new oil came through the flow also improved. I'm hoping to notice a better response from the 4WD system next time I hit the track.
So next is a catch can and a tuning session on the dyno. Then I should be right for track day.
On the handling front, I have front camber adjusters coming and should be ready. I'll probably run the street tyres at the track to get a baseline of where I'm at.
Many of you know this has been a long process getting her back running. I can't wait to get into some cruises etc once she is all sorted.
https://www.sau.com.au/forums/topic/141942-buffy-is-almost-back/
The rim repair guy is down the gold coast, his name is Noel 55376380. Price was really good. I just gave him all four wheels. Nice to not have that vibration anymore. I think they got damaged from age, potholes and ripplestrips.
She has been off the road for a while, the car was perfect until I started some mods that didn't go so well. But all of that has been sorted now and I have a two stage plan with Mick to get her where I want. Can't wait. I have missed so many cool events.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
