i got a rb25det and gear box to throw in my r32. but the engine doesnt hav a turbo. so i am plannin to get sum thing bigger... gt35r ball bearing. i jst wanna noe what else is needed to run this turbo. i am goin to run this turbo on the standard engine. i noe that i need a mainfold, computer, injectors and waste gate... and wot kinda fuel set up do i need? can i use a bigger fuel pump or hava surggie??
a bigger fuel pump will do the trick, you'll also need a front mount if you havent already got one, a 300ZX air flow meter, twin plate clutch, fuel pressure regulator, new dump pipe...
a single plate clutch will do the trick as you probably wont be going over 300rwkws. But if you are or do then yeh a twin plate maybe in the equation.
You may not need a manifold either as you can use the std one but grab one of AM-PERFORMANCEs external wastegate adapters.
A bigger fuel pump is a must. Grab nismo injectors as they are direct bolt in...no bullshit like with sards.
so is this all i need? so that i can make a tick list of wot to buy
*manifold
*wastegate
*bigger fuel pump
*fuel pressure reg.
*dump pipe
*injectors
*computer
anything else??
$4000 to pay for the above
The quest for horse power is never ending.
All depends how much $ you have
Turbocharger
manifold
custom dump pipe
external wastegate
screamer piping (plumbed back if u want)
aftermarket ecu
Z32 AFM (if you chose an ecu like Power FC that requires one)
larger injectors
larger fuel pump
front mounted intercooler
custom intercooler piping
pod filter
all that and a good tune will make it work properly....
Edited by _8OO5TED_
*manifold
*wastegate
*bigger fuel pump
*fuel pressure reg.
*dump pipe
*injectors
*computer
anything else??
Would it not be cheaper to sell yours to a P Plater and buy a Turbo?
Your looking at around $3500 for part and maybe $3000 to fit it up with tune .
And you are unsure if the set up is going to work well
Just my 2c :D
Edited:Sorry, did not see a reply similar earlier.......me bad
    • Jamie does know his stuff , you might just want to give them a call and ask - here is their FB page  -  https://www.facebook.com/profile.php/?id=100063506985512 - you will find the number to call them on.
    • Do you think the guys in Penrith are install the E85 Kit?
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
