Hi,
I had a GReddy Turbo timer installed earlier in the year, the TT came with a speedo in which at time of installation was not setup. I finally found the time to go through and check where the "Purple" wire for the TT actually went to and turns out it was taped in a loop to itself just near the hand break. I need to join this with the cars speedo, but unsure as to which wire that is... does anyone know which wire i would need to join this with in an 1996 R33 GTST Series 2?
Regards
Jamie
https://www.sau.com.au/forums/topic/142003-96-r33-s2-speedo-wire/
i am also looking to do this.. I am pretty sure we need to do this by runing it off the speedo wire from the std ecu... The purple wire In mine is connected to the hand brake sensor though....for the safety shutoff...I guess it may work if you just bridge that wire from the hand brake to the ecu? as in the manual it says purple is the speedo wire... hmmm.. not to sure which one on the ecu is the speed sensor.
I have same greddy t timer... you can dowload the manual for it from greddy.com.... as mine came with japanese instructions. :)
Turbosmart E-boost 2 manual has the pin-outs and diagrams for heaps of cars including almost all turbo nissan cars specifically for speedo wire. All turbo skylines are included 5meg d/l off turbosmart.com.au
http://www.turbosmart.com.au/index.php?s=f...load&id=108
cheers
Evil
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
    • Turn it into the pride flag
    • I think you'll find we're confused about what you were trying to do and how you were doing it. I would have thought that block rigidity was something you measured while loading the block in beam or in torsion, and that you would do so before and after grout filling, to see if putting material in there created a "composite" construction with the expected rigidity increase. Notwithstanding that the true function of grout is less about gross rigidity than local (ie preventing bore deflection/splitting and tying the bores to the main bearing locations a little better, etc etc). It is nearly impossible to follow your description of what you've done without closing ones eyes and making "aliens" hand shapes in front of oneself to try to follow the manipulations you've made. It's still unclear to me what you were trying to prove.
