Hey dudes,
I have two of each fuel pumps for sale, and are genuine Bosch, comes with box, with and unopened box and seal.
Porsche 910 =$190
040 =$220
044 = 230
All Sold!!!!!
If I do get any more in, I'll will post up again!!!!!!!!!!
Edited by mr_r33gtst
https://www.sau.com.au/forums/topic/142012-geniune-bosch-fuel-pumps/
Hey dudes,
Porsche 910 =$190
040 =$220
044 = 230
Located in melb, pm me or givce us a bozz on 0421 111 542... CHeers
Price Drop!!!!!!! Need Them SOLD!!!
Porsche 910 =$150
040 =$150
044 = 170
These fuel pumps are all brand new in unopened boxes with the Bosch serial numbers
Prices are FIRM
Grab yourself a Bargain!!!!!!!
can u send it over to QLD?? if so i will grab a 044. does it come with the fitting?
Yep postage is $10, I've havent had a chance to fit these pumps on yet, but from what it looks like its just a pump, brand new in a box with an unopened seal..cheers
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
