hey guys
did a search but cant find many actual answers with proven results. everyone says 'yes my exhaust is quiet' but havent actually had it tested.
just got off the phone to a tester who claimed that no 3" system will be under 90db. can anyone prove him wrong? ive got a 3" split dump to a wide body hiflo cat, 3" cat back system with a hotdog muffler and jazma oval muffler. he claims it will be over 100db.
what have you guys got.
https://www.sau.com.au/forums/topic/142024-how-loud-is-your-exhaust/
  • Replies 55
my system is pretty loud, was a peII but took the centre part out and got a custom 3" straight pipe made for it or the same diameter. So i got a 3" dump big body cat and straight pipe to the rear >_<
My old 80mm catback with proper mid muffler and enormous rear muffler came in at 92dB at 4k. This was with a 3inch dump/front pipe and regular old ceramic 3 inch cat and highflow turbo.
I reckon the stock turbo would have dropped it a touch more as there was a noticable increase in exhaust noise after i went highflow
yeah would be hard to find a 3 inch that'll make it under 90db
mine used to be 115, but that system was rediculous...
stop livin in the past man !!!!!
how do you measure the db's anyway? i havent got a db meter.
CES dump pipes and 4 in straight thru no mufflers at all (track only car so no Cat) its fkn loud
Hang on is that a dB tester up my ass...when i extract it Ill get a reading
Edited by gtr660hp
3inch all way, as quiet as my wifes 'frontal' wet-farts
:):P:O
farken hell, did ya have to ??? huh? damn :O
i just put a 3" highflow cat on my turbo back 3" exhaust (mild steel, mandrel bend). and the fuccker is now slightly louder, but also very droney. i cant stand the drone. dont like the drone. would like the drone gone.
will a resonator return it back to the nice throaty note it had when running a 2.5" standard cat?
My friend has a db tested thing. Same as the exhaust place uses. He tested my exhaust at 108 db from memory. Then i made up this thing to go just after the cat. Just got a bit of tin cost me $1.75 from bunnings. Cut it to the size of the gaskit. drilled some holes in it and put in in the exhaust. Got may mate to test it again and it was 92db. The exhaust shop tested it at 86db.
Removed it after the test. I have a 3" system.
Mine was 86db at 800rpm... Went do 105db at 4000rpm or something stupid. Thats 3inch from the dump pipe back (stock dump). Just the cat and a cannon.
Then I got two big arse mufflers put on 84db at 4000rpm. Still 3 inch. Its just so much better, I can now hear my stereo on the highway.
the trust pe2 is def below the legal limit of 92db - it produces a very slight howl between the 3k and 5k range - but compared to the blitz nur spec its almost like a standard exhaust.... I think someone said its at 88db or there abouts
The legal limit is 90dB for passenger cars according to the information available from the official ADR website:
http://www.dotars.gov.au/roads/motor/design/adr_online.aspx
in particular, ADR 28 is what I'm referring to.
Note that ADR 83 apparently supercedes 28; but ADR 83 has plainly been written by someone who was smoking
some kind of illicit substance at the time (it's full of conditions like "if it's the second tuesday in the month after 2pm
but NOT in a full moon, subtract 1dB UNLESS the car is owned by an Amish vegetable farmer in which case add
1dB ENSURING that the summer solstice is observed"). I had a quick browse through 83 and I was unable to
determine what the noise limit for my car within 30 secs; ADR28 allows ready lookup so plainly our pollies
are doing their jobs of making things even more incomprehensible.
Idiots.
edit: T04Z, HKS 50mm gate, 4" stainless exh, 6" cat, 6" resonator, large muffler w/ steel wool:
85dB with restrictor fitted and closed
89dB with restrictor fitted and opened
93dB with no restrictor
97dB with small 6" rear muffler
Any exhaust place with a dB meter can measure; the measurement procedure is defined in the ADR.
The meter is supposed to be calibrated regularly too.
Regards,
Saliya
Edited by saliya
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
