hey guys
did a search but cant find many actual answers with proven results. everyone says 'yes my exhaust is quiet' but havent actually had it tested.
just got off the phone to a tester who claimed that no 3" system will be under 90db. can anyone prove him wrong? ive got a 3" split dump to a wide body hiflo cat, 3" cat back system with a hotdog muffler and jazma oval muffler. he claims it will be over 100db.
what have you guys got.
https://www.sau.com.au/forums/topic/142024-how-loud-is-your-exhaust/
  • Replies 55
my system is pretty loud, was a peII but took the centre part out and got a custom 3" straight pipe made for it or the same diameter. So i got a 3" dump big body cat and straight pipe to the rear >_<
My old 80mm catback with proper mid muffler and enormous rear muffler came in at 92dB at 4k. This was with a 3inch dump/front pipe and regular old ceramic 3 inch cat and highflow turbo.
I reckon the stock turbo would have dropped it a touch more as there was a noticable increase in exhaust noise after i went highflow
yeah would be hard to find a 3 inch that'll make it under 90db
mine used to be 115, but that system was rediculous...
stop livin in the past man !!!!!
how do you measure the db's anyway? i havent got a db meter.
CES dump pipes and 4 in straight thru no mufflers at all (track only car so no Cat) its fkn loud
Hang on is that a dB tester up my ass...when i extract it Ill get a reading
Edited by gtr660hp
3inch all way, as quiet as my wifes 'frontal' wet-farts
:):P:O
farken hell, did ya have to ??? huh? damn :O
i just put a 3" highflow cat on my turbo back 3" exhaust (mild steel, mandrel bend). and the fuccker is now slightly louder, but also very droney. i cant stand the drone. dont like the drone. would like the drone gone.
will a resonator return it back to the nice throaty note it had when running a 2.5" standard cat?
My friend has a db tested thing. Same as the exhaust place uses. He tested my exhaust at 108 db from memory. Then i made up this thing to go just after the cat. Just got a bit of tin cost me $1.75 from bunnings. Cut it to the size of the gaskit. drilled some holes in it and put in in the exhaust. Got may mate to test it again and it was 92db. The exhaust shop tested it at 86db.
Removed it after the test. I have a 3" system.
Mine was 86db at 800rpm... Went do 105db at 4000rpm or something stupid. Thats 3inch from the dump pipe back (stock dump). Just the cat and a cannon.
Then I got two big arse mufflers put on 84db at 4000rpm. Still 3 inch. Its just so much better, I can now hear my stereo on the highway.
the trust pe2 is def below the legal limit of 92db - it produces a very slight howl between the 3k and 5k range - but compared to the blitz nur spec its almost like a standard exhaust.... I think someone said its at 88db or there abouts
The legal limit is 90dB for passenger cars according to the information available from the official ADR website:
http://www.dotars.gov.au/roads/motor/design/adr_online.aspx
in particular, ADR 28 is what I'm referring to.
Note that ADR 83 apparently supercedes 28; but ADR 83 has plainly been written by someone who was smoking
some kind of illicit substance at the time (it's full of conditions like "if it's the second tuesday in the month after 2pm
but NOT in a full moon, subtract 1dB UNLESS the car is owned by an Amish vegetable farmer in which case add
1dB ENSURING that the summer solstice is observed"). I had a quick browse through 83 and I was unable to
determine what the noise limit for my car within 30 secs; ADR28 allows ready lookup so plainly our pollies
are doing their jobs of making things even more incomprehensible.
Idiots.
edit: T04Z, HKS 50mm gate, 4" stainless exh, 6" cat, 6" resonator, large muffler w/ steel wool:
85dB with restrictor fitted and closed
89dB with restrictor fitted and opened
93dB with no restrictor
97dB with small 6" rear muffler
Any exhaust place with a dB meter can measure; the measurement procedure is defined in the ADR.
The meter is supposed to be calibrated regularly too.
Regards,
Saliya
Edited by saliya
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
