Guys,
Basically, I am putting an RB25 turbo onto my RB20. I'll upgrade the fuel pump, and maybe get a fuel reg.
So given that the Walbro's don't flow aswell as the Bosch's, for a target of maximim 200kw, realistically I am guessing 180kw, what would be the best option?
It seems everyone has a go at the walbro's, but unlike the Bosch's they APPARENTLY;
- Bolt straight in (Don't require mods to mount/fuel lines/extra fuel lines to reach bottom of tank)
- Don't have 1/4 tank issues.
I will put the effort in to install a 910/040 if I have to, but is there any need? I don't want to get a 2nd hand GTR pump.
Cheers
Chris
https://www.sau.com.au/forums/topic/142054-walbro-vs-bosch-fuel-pump/
what about with the same amount of power ie 200rwkw but using an aftermarket turbo or high flow turbo maybe running about 16 psi max, would the walbro item still be sufficient. again on the rb20, reason i ask is that im in a similar situation as eXc.
That's where I am at aswell, as I will be using a bigger turbo (rb25) possibly a high flow.
walbro will be fine up to 200rwkw anything over get the bosch,
they really arne't that hard to fit. but if you are going to use the bosch you will probably need to run direct feed from the battery as the current draw is a lot higher than the stocker and may blow the fuse (it did in my car)
Cheers
why not the gtr pump? mine is doing fine on my rb20 upto 270rwkw
if you wanted a new pump i would go the 040.. my brother had one in his old r33 gtst and never had problems with the quarter tank issue.
I'm considering ripping my bosch pump out come summer as bosch pumps sound crap once the weather warms up.
I'll be dropping a new pump in so it will most likely be something along the lines of a tomei/nismo internal pump. They are both around the $300 mark. I won't go a second hand gtr pump as second hand really isn't worth the trouble when it may get a little lazy 6months down the track.
Where did you find that price? They have all been $400 + when I looked.
2nd hand - Same reason I dont want a GTR pump
I ran a walbro at 240rwkw and 16psi no problems on a hiflow turbo and 555 injectors, pump handled it all fine.
Yes, i've since sold and installed another brand, but I'm setting up for 270-300rwkw, thats a fair difference.
As did my "mint" GTR pump, had a workshop put it in, had been working fine for about a year until a couple weeks ago when my car started running very, how can i say, shit. Turned out it was the GTR fuel pump so i replaced it with a in tank VR commodore replacement fuel pump ($95 brand new, all i could find at the time) put my car on the dyno again to check A/F ratios and they were all sweet at 160RWKW
i picked a Denso high capacity pump that flows around 300 l/h. its a direct fit and its not as much hassle as a bosch pump with the messing around with the intank brackets and that. it cost me around $250 if i recall correctly
its good for around 300 rwkw.
anyway just thought i would give you another option
cheers
Any more info? The part number where you got it from? :whistling:
Any more info? The part number where you got it from? :wave:
AH you got the denso 500hp rated pump....thats what Im going....Ill try to get the part number tonight...a workmate of mine has one...
if you can get these for close to $250 you are doing well, they are a top pump...
and as stated direct factory fit, took about 15mins in same guys silvia...
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
    • Wish someone would start a racing series for Group A replica cars, a bit like Touring Car Masters but for 1985 onwards and not grandpa's falcon and/or Monaro. I know they race in some historic class but that's for original cars, no replicas allowed.
