Item: Koya wheels and tyres
Details: 18 inch Koya rims with Federal tyres. Front rims are 8" wide and rear are 9". Front tyres are 235's and rear is 265. Tyres have travelled only a couple hundred kms so they are basically brand new. The wheels are in new condition with no scratches or marks. The set has only been on a car for a short time so are basically brand new. The wheels are to suit Nissan Skyline's and anything with similar stud pattern.
reason for selling: doesnt suit my gtr as my front gards a flared a little and just doesnt look right :) looks like i need a 5cm spacer
Price: $1800
Contact: PM Please call 0409 776 085
pics: http://www.thegodzilla.com/car-parts-for-sale.php
Edited by druzilla32
https://www.sau.com.au/forums/topic/142077-koya-18-wheels-tyres/
  • 3 weeks later...
  • 3 weeks later...
if you took my offer of 1500 and said 1600 these would have been sold then now. Now your stuck with the ryms
GL with sale
no need to be rude, I had only just advertised them for sale so thats why i didnt take 1500.
if you dont want them then dont post here
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
    • Not great at getting the camera out fast enough for cars driving. Even in traffic. S15 is in front of the kei truck.
