I currently have an R32 gts that has had an RB20det put in it. The gearbox is also RB20DET. but the diff feels like a single spinner it will allways spin the inside rear wheel and when jacked up the wheels spin in opposite directions confirming it in not an LSD.
I have had a look at it and it has 6 bolt half shafts. (3 x 2) bolts. it also has a 4 bolt finned rear cover is it a GTS diff or has it already been converted to GTST?
Are R32GTST diffs 6 bolt half shafts or five?
I think a factory lsd in good nick will be good enough for my needs, so I need to know what sort of diff will bolt up.
I would prefer doing this to taking the centre out and putting a new centre in my housing as I will be putting it in myself and I dont have good or big enough sockets to go pulling crown wheels off.
Can someone list what sort of diffs will fit? Will a GTR mechanical diff fit?
Thanks!
https://www.sau.com.au/forums/topic/142097-diff-replacement-options/
From what I gather...
you can replace the diff centre (shortnose R200... whatever that means).
this won't change the ratio, and is what I would reccomend. Except get an aftermarket mech 1.5 way...
I THINK that you could swap in/out a whole diff. (but I'm not sure... and the rear driveshafts might be different).
second hand lsd's (stock r32 gtst or gtr) will be a bit of a gamble. I recommend something aftermarket such as a Cusco/Kaaz/Nismo 1.5way etc.etc.
You also need to confirm that you have an R200 housing, and it's not an R180 housing. I'm not sure if any of the skylines came with R180's across the range of non-turbo r32's but it's something you need to check, non-turbo s13's came with r180 housings, and the r200 housings and driveshafts bolt straight in.
if it's an R200 housing, an R200 diff centre will fit, but you may also want to check that you're happy with the ratio.
I recommend taking diff's to a diff place to get centres fitted if you don't know what you're doing, because there are shims and washers and crap that align the diff centre with the pinion/crownwheel. A friend once stuffed the alignment up on an Rx7 diff and the diff crapped itself after a week or two....
Will do,
I have spoken to sss automotive and they have a R200 with 3x2 half shafts that will bolt into my car but at this stage they do not know wether it is a 1, 1.5, or 2 way or what brand it is.
they want $700 for it. I might get them to find out exactly what's in it and if it's a 1.5 way kaaz/nismo I will take it :D
or does $700 sound too much for a 2nd hand diff.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
