Installing a Oil Pump
Guest JOnJ0n
I have a quick or maybe no quick question. When you install a oil pump do you have to line anything up. Now my oil pump was intact the whole time and I didnt take it apart since that oil pump was on a another engine block I used to run before. Also is there anything for timing wise you need to line up. I heard about something hacing to do with the timing gear and the protective piece on the oil pump that protects the bottom of the timing gear... Have you heard anything about that?
https://www.sau.com.au/forums/topic/14210-installing-a-oil-pump/
