Rda Rotors Group Buy - 5th & 6th Batches
Received my rotors today. Just want to double check that the rear rotors are the same for R33 GTSt and 300ZX TT which is what is marked on the box? :S
Yes, All 300ZX TT uses the same rear rotors as R33 GTS-t (Part no 908) - they are interchangeable.
  • Replies 113
Allright guys, for batch #6:
1. RB_n00b - R33 gtst full set 7693S & 908S rotors - payment received
2. Simonster - R32 late GTR front 7701S rotors - payment received
Just to make it clear how this work: I do not work for RDA, and I do not personally send the rotors to you. (I don't even get to see the rotors.)
I submit the combined order to RDA (as an SAU Group order), and they do all the delivery and arrange where and which warehouse they got the stock in.
I believe when it comes to shipping RDA do it in one whole batch of all of you (logically they should be doing it that way to avoid confusion). So if the others have received theirs, it's just a matter of days before they get to you. As you've given me your daytime contact (mobile) it should have been written down on the delivery docket too so the courier can call you if no one was home.
But if yours haven't turned up in the next few days I will follow up with RDA - from the past 4 batches usually it's because no one was home and the courier could not get call the recipient (phone not provided, wrong phone number supplied, not picked up, etc).
I'm still waiting for a couple more transfers to go through, some said are transferring tomorrow as well, so looks like at least monday or tuesday for me to submit the order. It's a lot easier if I submit the order for 5 or 6 people in one go, rather than 3 tomorrow, then 3 on Monday...
Some transfer (e.g. electronic from other banks) may take 2 days to appear that's another reason for me to wait...
Monday evning update:
3. alexk - R32 GTR front 7926G & rear 908G - payment received
4. Fra22 - R33 Gtst front 7693S - payment received
5. xolent (welcome back) - 7500S & 478S - payment received
6. babia - R33 gtst rear 908S rotors - payment received.
7. IanB - R32 GTR (early) - pending payment
8. Deceeve - R33 Gts-t 7693S - payment received
To prevent delays to others who have their payments cleared, Group Buy #6 is now closed.
Batch # 6 will be submitted some time tomorrow afternoon. Will give you guys update in this thread tomorrow...
Guest
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
