Hey all,
Im 16 and recieved my L's a month ago.
This weekend, me and my dad went to adelaide and bought my first car.
It's a black R32 Skyline, RB20DE non-turbo, 5speed.
I have only been researching into cars for the last 3months. I firstly wanted a 300ZX Z32, then a S13 180sx, then an EL XR6, then a S13 silvia but i decided an R32 would suit me lol.
So i have just a few questions.
How can I increase the power/KW/acceleration of my car without adding a turbo as I'm not allowed one lol.
What do i need to buy in order to get that sound of air coming out, everytime i change a gear?
Thanx in advance.
P.S I don't have a job, and since dad bought my car I need to spend my own money on doing it up. So orices would be appreciated. Thanx :)
https://www.sau.com.au/forums/topic/142116-noob-help/
Some friendly advice from someone who has been driving a lot longer than you've even been alive - just learn to drive the thing first.
Please, the last thing anyone here needs to hear about is some hyped-up youngster, fresh onto his Ps, wrapping himself around a tree because the car he was driving was beyond his ability.
Patience, young grasshopper.
https://www.sau.com.au/forums/topic/142116-noob-help/#findComment-2647257
a turbo. :(
There's plenty of threads on how to get power gains from NA engines in the Naturally Aspirated Performance section.
https://www.sau.com.au/forums/topic/142116-noob-help/#findComment-2647845
Hey all,
Wont get that without a turbo...
Thats an Atmo venting blow off valve.. and it doesnt whoosh every gear change.. only if the turbo has spooled enough
https://www.sau.com.au/forums/topic/142116-noob-help/#findComment-2647868
    • Is that the blue one rpm?
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
