i bought an "autogauge" gauge from "online depot" also for pretty cheap
they provide a good product for cheap, but there is a couple of weeks delay with them..
worth it for the price you pay :whistling:
I'd use a different quote.. "you get what you pay for."
Like a few people in this thread, I bought a black face autogauge meter from the same place.
Prompt delivery and the product looked alright. Hard to see the needle in daylight though.
After a couple of weeks I was bothered by the rest position of the gauge ( reading when engine was off ) plus it was reading about 4 psi on stock gtr actuators.
Scavenged a mechanical test gauge from work and used it as a reference.. was sitting on about 9psi.
Meter was filed in the round filing cabinet..
Ordered an a'pexi mechanical el meter to replace it and am much more confidant of a correct reading.
I wouldn't consider a correct reading gauge a luxury.
James.
  • Replies 45
quick question regarding install
comes with a long length of clear tubing which you attach to rear of gauge then run into engine bay, then there is a short lenth of a larger size tube which you attach to t peice from vacuum line...should i just use the smaller sized tubing all the way or buy some more tubing the same size as t-peice & run that all the way into cabin then use a tiny amount of the clear tubing just to attach to rear of gauge?
Thanks
Noel
Ok installed gauge on weekend...I put it where the ashtray is supposed to be...Just took it out, cut a bit of mdf to fit then cut out hole in middle for gauge, stuck some grey carpet that i had lying around on, put gauge in mdf, it hooked it all up then pushed mdf into space & presto i now have a boost gauge in a legal spot...will post pics when i take some.
Only drama i had was a tiny one where T-peice did not fit original vacuum hose to inlet but i replaced this with left over 4mm hose that i had used instead of the clear nylon tubing that comes with gauge & was all good
Edited by Noel
Here are some pics I took yesterday, with my new camera, of my dash/center console:
Ricey I know lol
Click here for more pics
Its been sent but Aust Post dont know where it is...Mark is chasing it up with them
Received, seems Australia Post magically found it, & it showed up at reception once we enquried about it.
All good its here now so now i can go and play ;-)
Also my turbotech does not have a little pin hole in it...in the original thread for these i saw a few others also had no hole & one was even told its the new design...is this a problem or is it all good?
Cheers
Noel
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
