Hey Guys,
When my climate control changes from face to feet (between some modes) I hear clicking and clunking noises. I figure the servo gears are jumping because some flap/duct has come loose. Maybe even some foam/rumbber seal jamming in there.
Does anyone know if this unit can be pulled apart for me to look at and repair or is it a sealed unit that has to be replaced. I figure the whole dash has to be pulled apart? Any ideas or comments welcome.
Cheers
https://www.sau.com.au/forums/topic/142200-climate-contr-duct-flap-noise/
my car does the same thing. from what i've read in a previous post somewhere it has something to do with the contact points on the vent flaps. because the cars are fairly old the motor doesn't receive a signal to stop trying to move the vent flap. you'd probably have to pull the whole dash out to try and fix it. i find if you leave it blowing towards your face and dont change between the two settings it doesn't make too much noise.
Yep that's right, if I leave it fixed in any mode (usually face + feet) it's fine. It's only if you leave the CCtrl off then it cycles through on startup. If it's just contact points then it may be an easy fix as long as I can get to them easily. I want to sell this car someday so it has to all be 100% working. It's the only thing on my car not working properly.
  • 1 month later...
I've heard a simliar buzzing from mine, I also get a puff of hot air if i gun it sometimes. Most noticible on the freeway. Anyone get that too? I reckon its gotta be either the air mix flap or the heater tap/controller thats built into the heater core on my car.
Deren
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
