I was just wondering if you could buy a gauge to connect to the factor knock sensors? This would probably be a lot more reliable than the widely available AFR gauges.
If not would it be possible to make something Jaycar style with a warning light?
I know the PFC reads knock however I already have an EMS.
https://www.sau.com.au/forums/topic/142246-stand-alone-knock-sensor-gauge/
Hey Turbo87
Unfortunately I think you’ll find the smarts of a OEM knock system are in the micro controller, not the sensor.
The sensor is similar to a microphone, though with a heavy weighted center pole section instead of a delicate mylar cone. Vibrations go through the sensor and shake the center piece causing current fluctuations through the coil blah blah.
The sensor output is then read by a micro controller which is able to remove normal engine vibrations and concentrate on the larger knock events.
Its that algorithm that’s the key, and the reason why EMS don’t supply the ability with their ECU’s.
Your not f*cked yet, there’s a few options.
I rem a Zoom mag back in high school with a red turbo 240Z, back when it was still published on matt, mostly black and white paper had an article about using the decoder from a Delco?
>> http://www.linkecu.com/products/AncillaryDevices/KnockBlock
This mob known for ECUs’ that catch on fire ( recent HiOctane vid) have been making systems for years
>> http://www.techedge.com.au/
If your already making the hardware to heat / control and decipher wide band sensors for the tuning industry, one could guess where the next avenue for development would be – stay tuned
Lately I have a habit of spewing coffee fueled Hi-Po auto utopia at the end of my forum posts, this time I gota grip ;)
Hope this helps buddy
Michael
HKS make a combination Knock Amp and A/F ratio meter, they are around $900 or so. Very usefull tuning device, bit exy though.
The cheaper alternative ($150 or so) is to buy some chassis ears and use the best knock detector known, the human ear.
Of course Power FC's come with highly accurate knock amp included and display easily interpreted knock readings on the Commander (or Datalogit if you have one).
:verymad: cheers :sick:
The stock ecu will spit out a knock code (code 13 I think) if the knock becomes higher than the factory preset (which is conservative). Of couse you need a consult cable and software to do it though.
But you haveing an ems means its not much help here. :-(
i think the only fault code the ecu logs is if the knock sensor circuit isnt correct, not that its detecting knock over a certain level (code 34). some consult software like nissan datascan incorrectly reports it as simply "knock sensor" and most people interpret this as being that the ecu recorded a knock
Well Yeah I thought that once too but if you have a good read throught he nissan manual for the R32 you'll find that it does document this. If the stock ecu detects knock it will switch to the secondary map for fuel and ignition.
I tested this theory quite some time ago and everything lines up.
It will spit out a knock code if the ecu detects knock beyond the ecu preset.
The stock ecu is a wonderfull thing.
R32 FSM, EN-396 says knock sensor fault code is only indicating disconnectiong/short circuit (or relating circuit issue).
it makes no mention of the engine registering a knock resulting in a fault code. maybe your sensor and/or wiring whenever you tested it was a bit iffy?
EN-297 says the same thing for the R33 FSM (that the fault code indicates "disconnection or short circuit in the knock sensor")
likewise for EC-51 in S14 FSM, and S15 FSM says similar things as S14 one
Edited by NewKleer
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
