+++white Face Dials @ Bezels+++ Get In Now
  • Replies 271
Posted Images
I'll go with the Blue Metalic and brushed bezel with rings please for R33 Series 1 Manual GTS-T
Thanks for organising this btw.
Edited by Filecon
Hi Kezza,
Can you please put me down for a set of blue metallic dials and brushed bezels to suit a 97 manual SII R33 GTS-T
I also would like to get a blue LED light kit if that would look the best with the blue metallic dial.
Thanks for your time and help
Mark
Hi Kezza,
Mark
PM me mate and ill send you my detalis
kezza
Hi Kezza,
Just letting you know i made the payment just after lunch today and I look forward to receiving the goods whenever they arrive.
Thanks again for organising this :happy:
Mark
kezza
Hey Kezz,
I sent a PM to you this morning at 1am asking for the banking details. I haven't received a message with the information of your banking details. I hope I don't miss out.
no ,mate..... this is the cut off now!!!! just wait on a few people to finish deposits! and the order will be sent off!!!!
give filecon a chance bro! :stupid:
he posted on Dec. 6, mate!!!
Damn gutted i missed this, only just got on this site.
those blue met dials look wicked with brushed surrounds and leds i would have been made up. $300 ish
any chance ??
Spec 1 R33 auto
Edited by Allkiller
ditto, need the correct bsb number aswell
Guys,
I received an abbreviated BSB also, but I think it's 06 in front of the BSB for CBA.
I'll try and let you know.
It worked. ;)
Give it a go guys. Just hope it goes to the right account :P:thanks:
BTW thanks i-styleinc :sorcerer:
Edited by Filecon
:action-smiley-069: yeah thats it! the 06 is just the code for AUSTRALIA.... i had one guy have problems getting it in, so i ausmed it was because i added the 06 area code in!!!! but yeah the full BSB number is::
06 4403
sorry about that!!!
cheers
kezza
GB UPDATE:
Japan has just got the order list from Kezza.
We are now double checking all the info. on each members car
and will then process the order.
cheers,
Mike
  • 3 weeks later...
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
