+++white Face Dials @ Bezels+++ Get In Now
  • Replies 271
Posted Images
UPDATE:
ORDER HAS BEEN PLACED, MONEY SENT OVER, MIKE SHOULD HAVE THEM IN JAPAN, WITH IN A FEW DAYS, THEN A WEEK TO GET TO ME... THEN A DAY OR SO TO GET TO FINAL HOME :(
GIVE OR TAKE A FEW DAYS....
BUT YEAH ALL GOING WELL....
MAYBE ONE DAY ILL HOLD ANOTHER GB. PENDING ON HOW MANY PEOPLE WANT THEM.
CHEERS GUYS.
KEZZA
new update... the order has been filled, and will be sent off to me sometime this week!!!!! NOT LONG NOW.. then once i have them, ill send them out to you all asap!
cheers,
kezza
Kez, I trust that when they are sent out, that they'll be packaged very well in rigid packing?
e.g. I'd prefer not have the guy at the post box try and fold it in half and stuff it into my post box, or have the postman chuck stuff on top of it and put creases and dents in it.
Cheers matey
dude...... no one had any problems with the last GB with packing!
but yeah thanks for the input........................
Not accusing in anyway. I'm sure that you have put a lot of effort into doing things right. I'm just seeking reassurance.
Cheers
Kezza it's been a week since your last reply.
Please post an reply, even if you don't have any new updates. A week's silence makes people nervous! :P
sorry people.. dont get nervous... the stork order has been filled... and im just waiting for them to get to me from jap postal!
along with other stuff i have on order!!!
so dont worry, i have been hounding my mate, just as much! lol
hahahha i know i know!!!!!
they are in brisbane, they have been stuck in customs for the passed week!!! the pricks are trying to charge me 10%GST + 10% import tax... cause they are all worth so much!!!!
But lucky, fingers crossed i have found the loop hole and wont be screwed over by the customs boys!!!
But apart from that they would have been here over a week ago!!! :)
:santa:kezza will be sending off his parcels soon enough :)
im bored!!!!!! I miss my car sooo much!!!! ill share some pics of what she is up to one her paint job!!! shhhhh dont tell anyone!
i have it all in my head of what it will look like in the end APART from the big T wing i have fitted to it!!!
im still unsure on it!!! i spose it wont stick out too much when its alll the same colour as they are, and wont stick out like a booggaannnn! (i hope)
Guest
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
