+++white Face Dials @ Bezels+++ Get In Now
this link is to the current status of the parcel containing the Cyberstork meters. The c**ts at customs have decided to have fun with our parcel and are scrutinizing every detail. Ontop of that, they have been very slack in returning our calls, but please bear with us, Kezza and I are doing our utmost to get this thing cleared ASAP!
http://tracking.post.japanpost.jp/service/...P&locale=en
the tracking # is EI698268461JP sent via "E.M.S. Postage" (supposed to be 3-day express but is turning into 3-weeks)
Thank you for your enduring patience in the matter,
Mike, Cyberstork/J-Style Inc."
It has been all sorted... the parcel has been cleared , i should get them in the next day or so!!
about f**kING time!
  • Replies 271
Posted Images
they're very easy to install guys.
Xixor, if you need help with the leds or any of it, feel free to give me a buzz.
Basically, you remove the dash face, remove the cluster surround, take the cluster off. It's about 3 screws from memory.
The front clear face of the cluster is just clipped in. once you hvae it out, you'll know how to remove it. just push the clip in with your finger nail.
The leds are easy. you just undo a few caps at the back of the cluster, and the leds are inside. Straight pull the old one out and put the new one in. just like changing a light bulb.
For the faces, just cut them out and slip them over the needle. DO NOT remove the needle, otherwise you'll f**k up the cluster.
Edited by MANWHORE
do they come with directions on how not to fk up the install lol ?? :stupid:
This will help when it comes to pulling apart the car as well...
R32:
http://www.cyberstork.com/cgi-bin/howto.cg...p;imgtp=skyline
R33:
http://www.cyberstork.com/cgi-bin/howto.cg...amp;imgtp=ecr33
Once my kit arrives, I'm gonna see how many LED's are needed, and place an order with this mob:
http://www.ledshoponline.com/automotive_dashboard_bulb.htm
The T5 LEDs (which Im pretty sure the skyline has in the dash) are only $2 each... And they are the new "Wide Angle" ones as quoted above... As per the first post, there is 8 LEDS in the dash... so you can buy your own LED kit for $16 + $9 Shipping :stupid:
Note - I only just looked this company up now... sorry to those guys who have purchased through the group buy. Im sure those ones will come with instructions and will be better quality led's anyway :yes:
yeah man.. The leds are easy to fit!!! just plug and play items... only you need to make sure they are in the correct way!! one of 2 ways, lol one way wont work and the other way will ... they have built in diod so they will not blow if in reverse polarity!
but yeah the led kits we have are in sets of 4.. unsure if you would need more.... wouldnt think so!!
Had a look through the site listed above... and yeah they are just normal leds aranged in formation so they will give the best light hey can , because they are not full wide angle leds! as much as they say they are!!!
As the ones who ordered through me will see, that they are bright as hell! I know, i hooked one up to check it out , and i was BLIND for about 15min, lol.... well not fully blind but i could see a full on black area in my vision for ages...
they are $$$ because they are alot more powerfull, and they even have to have a small heat sink built in. they make that much light!!! Dont worry the heat sink WILL take the unwanted heat and WONT cause any problem, still not as much heat as a normal globe would make anyhow!!!
I could go on and on about leds, my car has alot of them... lol!!
the reason you need WIDE angle leds for dial app is because you only have 30mm or so from the point of light o the back of the dial its self.. now if you have a copy of a wide angle led you will see when they are on one point that is very bringt and dull around it!!!!
the WIDE angle leds have close to 180' of light chucked out so an even light will be showen on the dials!
If you missed out on the hi power led kits, ar maybe want more, the first led on that page listed above would be the best that site can give !! The rest are no good !
Im in the midlle of making a set of led tail lights for the R32!! using stock tails so you dont have the bling look of the aftermarkit ones. And just to have something full custom! then ill sell them!!
hahahah and no im not just going to bung a led blobe in the back... lmao
Cool!
Xizor, let me know what turns up in the kit :)
Also, the stuff was coming via snail mail yeah? Just need to know when to look out for it ;)
hahahaha.... they will be ok when the dial plates are over them! lmao
you can always go hard core like me and have so much stuff that lights up that people call it the star ship enterprise!!!
yeah it should take about 3 days max! well maybe 4!
cheers dudes.
Guest
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
