Hey there,
Have afew things up for sale. I will post to anywhere in australia at buyers expense.
RB25 Standard Dump Pipe with shield - $15
R33 Standard Intercooler with pipes that are in picture. One of the pipes has another thread put in it could use this to hook up a boost gauge or could just block it of - $20
R33 Series 1 Type M Front Bar indicators - $50
R33 Series 1 Drivers Seat Plastics -$30
R33 Series 1 Grill Black - $40
Edited by iLEC
https://www.sau.com.au/forums/topic/142266-r33-parts-for-sale/
one problem mate....... where arer the rims that ya wont post?
sorry mate the rims are in adelaide :whistling:
i will have pictures of the rims and the grills shortly
the rims are HR Racing rims they are 7.5 wide by 18 high not sure on the offset how can i tell? if your in adelaide u can come try them on the car to see what they would look like :yes:
please somebody buy some of this stuff so dear old dad :thats me"can get some shed space back mmmmmm wonder if i should list his car as well lol just teasing ya son
free bump
fairly intesrested in the turbo, does it run alright or need a rebuild? are you in adelaide?
the turbo was running fine when we pulled it off. it was only taken off so we could fit a hks 2535. and yes we are in adelaide on the north side .
you can come and inspect if you wish regards
allan
