Can people stop asking if i can send the rims interstate it clearly says in my original post that i wont send the rims interstate I WILL NOT CHANGE MY MIND any more pm's regarding the rims been sent interstate will not be answered anymore
Cheers iLEC
Mate i'm keen on just the stock cooler piping. I'll give you $25 posted to 3931. Looking at the australia post website postage should be around $5-10.
And you can keep the cooler... :-)
Cheers,
Rhett
  • 3 weeks later...
