  • Replies 71
im amazed this topic is still going lol, so many stories, why does everyone race against holdens and commodores? i thought there would be more agaisnt civics and elantra's and excel's, is it because the N/A skyline will lose against the civics?
i used to own a N/A r34 thought it was fast but really they are very slow, then i decided to get a real car and got a gtt but decided its time to go the top of the pecking order and got a man's car, a r34 gtr!.
let the angry people begin posting lol.
Z32 Slicktop 300ZX, 1420kg making 131rwkw. Faster then your average NA liner, by quite a lot.
that's nothing really special. i had a manual magna making the same sort of power with just an exhaust, weighing about the same and while they are a bit quicker than a NA 'line or commodore (ran high 14's), they certainly aren't blow the doors off quick like the turbo skylines are compared to a v6 commodore. but then it depends on whether the car you are racing is auto or manual. cause if it is auto and yours is manual then of course you are going to do better.
I love this thread =\
You lot may aswell have a power walking race...it would be more exciting than watching worn out NA auto skylines trying to race 3000000000000000km old VN wagons with Hayman Reece towbars and a caravan on the back.
Yeah 3L VG30DE motor, no 0-100 times yet....but it goes alright for what it is with minor boltons.
Take a video if you can ? I'd like to see how one goes...always been kinda curious about the 300zx's.
Peak power isn't super high but i bet the torque is pretty good.
I had a fto gpx as my first car, and from 2l it put out 116 fwkw on tightarse dyno. Need to rev rev rev those type of n/a motors though and forget about it if you're going up a hill lol. It was fun still making power at rev cut 8200rpm though..
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
