Wondering if anyone could tell me if this is anything to worry about.
The last couple of days I've noticed when starting the car the standard boost meter needle in the instrument panel goes straight up till almost the '0' level and stays there. When driving if you put your foot down eventually the needle will move hight acording to how much boost etc. But will always go back down to just under the '0' level.
Also I have an aftermarket boost gauge installed and it too I've noticed is stitting high than normal!
I'm not sure what's going on, I don't think it's the std meter playing up as the aftermarket gauge is doing the same thing. I've checked the lines and all seems fine.
Any help would be appreciated.
Cheers!
https://www.sau.com.au/forums/topic/142305-std-boost-gauge/
any loose hoses or anything?
sounds like its not recording the vacuum pressure when off boost..
as if something were leaking and causing it to stay at no positive/negative pressure.
From what I could see the hoses were ok, unless they are slighty leaking! I'll have to go over them again and look a little closer.
https://www.sau.com.au/forums/topic/142305-std-boost-gauge/#findComment-2649580
yeah, thats why it sounds like a leak.
if its reporting slightly higher than usual, but still at a vacuum, it means that there is slightly more pressure inside the plenum, ie there is position pressure leaking into it..
is it idling any higher? butterfly may be slightly more open..
apart from a leak, both a mech. and elec. guage raising has me baffled.
https://www.sau.com.au/forums/topic/142305-std-boost-gauge/#findComment-2649818
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
