extremely common problem...u'll have to remove the bulbs, remove the headlight cover then put some hot water with CLR or whatever inside it, let it sit for a bit, swirl it around (just like in the tv ad) then let it dry for a bit (u can use a hairdryer for this) ... now to ensure this doesnt happen in the future i found that some clear silicon around the mouldings and anywhere that it looks like water can enter into - will do the trick
You mean that dirty look or moisture in the head light.
For the dirty look, I used a heavy cut and polish, then a normal car wax that worked for me.
Cleaned em up well.
For moisture as above^^^^
  • 3 weeks later...
Was in a rear end/ front end ( long story but was not my fault), they had to respray the front bonnet etc, seems that the lights are now super fogged. can barely see through it. Will need to do this cleaning. Just wondering if someone who has done it can give me some pointers.
Do you have to remove front bumper? is this easy?
Do you have to remove the fron clear plastic thing then just clean that using the above methods?
I tried and gave up (didn't have much time). saw all the nuts holding it in. Will give it a go when i have more time.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
