extremely common problem...u'll have to remove the bulbs, remove the headlight cover then put some hot water with CLR or whatever inside it, let it sit for a bit, swirl it around (just like in the tv ad) then let it dry for a bit (u can use a hairdryer for this) ... now to ensure this doesnt happen in the future i found that some clear silicon around the mouldings and anywhere that it looks like water can enter into - will do the trick
You mean that dirty look or moisture in the head light.
For the dirty look, I used a heavy cut and polish, then a normal car wax that worked for me.
Cleaned em up well.
For moisture as above^^^^
  • 3 weeks later...
Was in a rear end/ front end ( long story but was not my fault), they had to respray the front bonnet etc, seems that the lights are now super fogged. can barely see through it. Will need to do this cleaning. Just wondering if someone who has done it can give me some pointers.
Do you have to remove front bumper? is this easy?
Do you have to remove the fron clear plastic thing then just clean that using the above methods?
I tried and gave up (didn't have much time). saw all the nuts holding it in. Will give it a go when i have more time.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
