tridentt150v Posted November 8, 2006 Share Posted November 8, 2006 Pretty sure its all OK, just checking, I want to low mount a garrett GT3076R IW [gt30r] on a s/s manifold. Is there any issues with clearance, any mods to make? I am assuming not, its a straight bolt on, but would like confirmation. Link to comment https://www.sau.com.au/forums/topic/142367-low-mount-3076/ Share on other sites More sharing options...
tridentt150v Posted November 8, 2006 Author Share Posted November 8, 2006 No one? Link to comment https://www.sau.com.au/forums/topic/142367-low-mount-3076/#findComment-2654048 Share on other sites More sharing options...
Cubes Posted November 9, 2006 Share Posted November 9, 2006 Depending on the manifold you may require a small spacer. Not expensive and not something you will have trouble sorting out come time to fit. Link to comment https://www.sau.com.au/forums/topic/142367-low-mount-3076/#findComment-2654281 Share on other sites More sharing options...
2BNVS Posted November 9, 2006 Share Posted November 9, 2006 definatley possible depending on manifold. i had a trust td07s low mounted on my car and thats pretty decent size, now its high mounted ben... Link to comment https://www.sau.com.au/forums/topic/142367-low-mount-3076/#findComment-2655941 Share on other sites More sharing options...
Devils_Advocate21 Posted November 9, 2006 Share Posted November 9, 2006 Must say have mounted my hks 3037 pro s with a 68 housing and the problem you might have as ive got at the moment and its a prick but mind you on standard stock manifold is the dump pipe to front pipe fitting maybe just me but the angle isnt quite rite make sure if your going to do it test fit dump and front to make sure of clearances Cheers a Link to comment https://www.sau.com.au/forums/topic/142367-low-mount-3076/#findComment-2656909 Share on other sites More sharing options...
The Mafia Posted November 9, 2006 Share Posted November 9, 2006 I have GT30r with a .7 Compressor cover and a .63 eh housing, and I needed two 10mm spacers. Link to comment https://www.sau.com.au/forums/topic/142367-low-mount-3076/#findComment-2657045 Share on other sites More sharing options...
